Current draw of the Scott Nixon Tubedac - anyone know?
0 Members and 1 Guest are viewing this topic. Read 1150 times.
byteme
Hello,
Trying to get info on the current draw of the Scott Nixon Tubedac (not plus).  Thinking of going with battery power for the little wonder and need to know what kind and how much battery will be needed!
Brian.
scottnixon
    • http://www.scott-nixon.com
« Reply #1 on: 3 Mar 2005, 08:30 pm »
You can not battery power any TubeDac via the power jack.  It will kill it' as it is designed for AC only.
byteme
« Reply #2 on: 3 Mar 2005, 08:54 pm »
Case Closed!  Thanks Scott!
Can I take from what you said that it could be powered by battery, however, it would have to be done in an entirely separate chassis or that it is not at all possible to power the tubedac via battery?
