SOLD - TeddyPrado Power Supply 15V- Excellent condition
0 Members and 1 Guest are viewing this topic. Read 499 times.
kenJay
Hi All, SOLD
I purchased this unit Teddy Prade PSU 15V that retails for $369 for my DAC, but realized after the purchase that I need 18V not 15v. So this unit is up for sale. In excellent condition as I cant find a mark on it and works perfectly.
Cable Diameter 5.5/2.1
Details from Teddy Pardo website below:
The Teddy15 power supply can be used to replace the small AC plug-in power adapter that comes with many audio equipment, routers, NAS etc, and provides significant improvement in sound quality.
The design is based on the experience gained with the TeddyCap family of power supplies for Naim Audio equipment, and uses the same technology.
Sound
In general, you’ll experience more clarity, tighter bass, more detail, better dynamics, natural voices, better soundstage etc.
Performance
The small power supply which is provided with most types of equipment is based on a technology called Switch Mode. Using this technology it is possible to create small, efficient, and low cost power supplies. Unfortunately due to their method of operation (high frequency capacitor charging), these power supplies are also very noisy, causing degradation in sound quality. As an alternative, several after market power supplies exist which are usually based on Linear Regulators. These regulators provides an improvement over the original power supply but as can be seen on the graph below are still limited in their performance.
The Teddy15 power supply is based on a superior regulator called SuperTeddyReg and provides a significant improvement over linear regulators.
The following graph shows the noise level measurements of the original wall wart power supply (red line), an alternative power supply based on a Liner Regulator (blue line), and the Teddy15 power supply (black line). The brown line is a zero Volt reference which is actually the measurement equipment internal noise. As can be seen the Teddy15 power supply noise level is very close to the zero Volt reference.
Thanks for considering, Much Peace
Ken
« Last Edit: 2 Oct 2020, 10:42 pm by kenJay »
kenJay
Re: FS- TeddyPrado Power Supply 15V- Excellent condition
« Reply #1 on: 27 Sep 2020, 01:36 am »
Bumperino ! Reduced ! to $225 Great unit, Thanks for considering, Much Peace, Ken
