Bdp-2/ Tidal fast tracks
0 Members and 1 Guest are viewing this topic. Read 791 times.
drummermitchell
« on: 15 Sep 2020, 01:39 pm »
Since I have been using my Bryfi-2 for the last month and decided to fire up basement system.
Bdp-2,Bda-3 ect.
I have Tidal and had installed a few tracks to my playlists on the bdp for a month or so.
Played the playlists with the tidal tracks and wtf.
The tracks fade in and only last around 30 seconds and fade out.
My tracks that I transferred from cd to my ext hard drive play normal.
This morning I search with tidal on my bdp-2 for the same tracks and put them on a playlist and the same thing,I don’t get what the heck.
Membership is good ect.
Couldn’t imagine if you had 20 or even 100+ tracks from tidal on your bdp playlist and this happens to all those tracks.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bdp-2/ Tidal fast tracks
« Reply #1 on: 15 Sep 2020, 01:48 pm »
HI Don
I am not an expert on Tidal but can you save tracks to a playlist?
Also what software are you using on the BDP?
james
drummermitchell
« Reply #2 on: 15 Sep 2020, 02:01 pm »
Hi James,
They are saved and no matter which track I play the all fade in and play about 30 seconds and fade out.
Latest software update high I always do whenever posted.
drummermitchell
« Reply #3 on: 15 Sep 2020, 03:40 pm »
Slap me seven times on Sunday,found the problem.
Seems I wasn't logged into Tidal on the BDP-2 under settings.
of  course I forgot user and password.
did a reset and now the Tidal tracks are calmed down just like me whew.
now playlist ect show up on Bdp-2.
now I know why the wife keeps saying she'll buy me a real nice radio.
