DBpoweramp conversion from ALAC or AIFF to FLAC?
0 Members and 1 Guest are viewing this topic. Read 1598 times.
matthewpartrick
  • vinnierossiforum.com
    • The Clueless Audiophile
« on: 12 Sep 2020, 07:52 pm »
Doesn't this seem pointless?  Am I putting lipstick on a pig?
I feel like converting AAC to FLAC in particular would be like making lemonade with rotten lemons.
Amiright? :)
Thanks in advance.
zoom25
Re: DBpoweramp conversion from ALAC or AIFF to FLAC?
« Reply #1 on: 12 Sep 2020, 09:18 pm »
AAC to FLAC makes no sense. Lossy -> lossless makes no sense. You're simply increasing size with no benefit and only negatives.
ALAC -> FLAC...maybe a benefit if one of your system has issues with ALAC. FLAC is more universal.
AIFF -> FLAC...you can get smaller sizes and save space while having identical copy of the music. That's a positive.
I keep music in both FLAC (highest compression) and WAV. Both have a purpose.
dB Cooper
« Reply #2 on: 13 Sep 2020, 12:33 pm »
Agreed AAC>FLAC is pointless- once data is removed, it doesn't come back (although aac 320 sounds pretty good)
Mike B.
« Reply #3 on: 13 Sep 2020, 07:22 pm »
Most of what I transfer to my digital setup is WAV. The only FLAC are downloads from HDtracks, etc. Makes download time far faster.
matthewpartrick
« Reply #4 on: 18 Sep 2020, 06:14 pm »
Thanks folks. Just converting from ALAC  and AIFF to FLAC then.
Thanks again!
matthewpartrick
« Reply #5 on: 26 Sep 2020, 11:41 pm »
All the ALAC and AIFF conversion to FLAC is going fine.  It sure is a lot of manual work though.  I'm using DBpoweramp converter.  Anyone else out there doing this?
aldcoll
« Reply #6 on: 27 Sep 2020, 12:16 am »
Dbpoweramp had a BATCH converter component.  I bought the complete package years ago and do not recall the various components or packages.
It is a 1 step operation when you set the options you desire.  It will do 1 song or 1 hard drive with dsp options.
Alan
richidoo
« Reply #7 on: 27 Sep 2020, 01:51 am »
+1 for the batch converter.  It works great.
The link to it is in the Program Menus.
matthewpartrick
« Reply #8 on: 2 Oct 2020, 04:31 pm »
Alan
I spent about an hour last night trying to get this to work but couldn't.  The files are on a NAS, and I cannot get DBPoweramp to find that NAS.  So, the work-around was to dump the whole music folder onto the computer hard drive (which I left to do overnight) and I'm going to re-try the batch converter tonight.
