SOLD: Carver MCt Moving Coil Transformer - $225
0 Members and 1 Guest are viewing this topic. Read 395 times.
tlarwa
« on: 11 Sep 2020, 01:02 am »
THIS HAS BEEN SOLD
I've owned this for a couple years and have used it successfully with an AT33PTG/II and a Zu Denon DL-103 MK2, and in conjunction with my Rogue Audio Triton phono preamp.  The case has obviously been repainted and new bumpers attached.  No issue with the unit, and it sounds great.  I can't confirm, but through my research I understand it uses Jensen transformers.
Specifications for the Carver MCt Moving Coil Transformer:
Dimensions: 6" wide, 2" high, 3" deep
Weight: 1lb 11 oz.
Gain: 24 dB
Signal-to-noise-ratio: Greater than 100 dB
Impedance: 3.9 ohms, 39 ohms, 110 ohms
Frequency Response: -3 dB at 3 Hz and 80 kHz
$225 + $10 shipping via USPS Priority in the CONUS
« Last Edit: 21 Sep 2020, 01:24 am by tlarwa »
