Vintage 2A3 5930 Vacuum Tubes For Sale - 2 Pairs Left (Updated)
0 Members and 1 Guest are viewing this topic. Read 995 times.
baileyler
VINTAGE 2A3 VACUUM TUBES FOR SALE – PAIRS AND SINGLES (13 TUBES TOTAL)
Everything except Pair #1 and Pair #2 is sold, so the ad has been updated.
If you want both remaining pairs, I would take $500.
This is a long listing with a lot of information, so please read it in its entirety.
Please also see the full Terms and Conditions below.
I have never used these tubes (and do not have an amp that uses 2A3), so I have no idea about sound.  As a general rule, I am not a good one to ask as most tubes sound about the same to my old ears.  Either I like tube or I don’t, but I don’t always know why (and it can change on a daily basis).
I do not know the history of any of these tubes so, for the purposes of this listing, all should be considered USED (even though some might be "new" old stock).
Some come with what appear to be original boxes, although most of the original boxes are brittle and missing pieces.
I tested these tubes on an Amplitrex AT-1000 connected to a regulated power supply.  The tubes were tested in fixed bias mode, and the test conditions are Vp=250V and grid = -43.8V.  The spec for “transconductance” (Gm) and “emission” (current draw) on the AT-1000 is 5.2 mA/V and 60.0 mA.
I also tested these tubes on a Westmore 501 (government version of the Triplett 3444), also connected to a regulated power supply.  According to the Westmore tube chart, Gm spec = 5200 and reject = 2600.  While there is no Westmore spec for plate current, the settings on the Westmore indicate that the test parameters are 250 Vp and -40V grid bias. According to various data sheets, the Class A plate current spec at 250 Vp and -45 V grid bias is 60 mA.
You can see below that the correlation between the Amplitrex and Westmore is remarkably good.
I can provide additional information or pictures on request.
Pair #1 - Miniwatt (Visseaux) $300
These tubes are branded Miniwatt but are Visseaux (French) made.  They are black double connected plate with a single bottom foil/dimple getter element.
The results on the Amplitrex are as follows:
Tube #1-1   5.35 mA/V    62.4 mA
Tube #1-2   5.60 mA/V    61.2 mA
The results on the Westmore are as follows:
Tube #1-1   5400   68 mA
Tube #1-2   5600   68 mA
Pair #2 – 5930/2A3W (Industrial 2A3) $300
The 5930 is an unusual version of the 2A3 with a short bottle and a fat brown base.  The glass is grey, there is chrome top (flashing), and internal construction is dual flat black plate.
Tube #2-1 is a Sylvania branded and made JAN-CHS-5930 with a date code of 138 and what appears to be an original box.
Tube #2-2 is National Electronics rebranded and Sylvania made.  Please note that this tube has a very small chip out of the top of the base, but it in now way affects the stability of the base or the functionality of the tube.
Because of the structure of the base and the fact that the Amplitrex has a set in 4-pin socket, I cannot readily test these on the Amplitrex.
If your amp has set in 4-pin sockets, you will likely need some type of adapter to use these.  Please keep this in mind when purchasing.
I did test these on my Westmore 501, and the results are as follows:
Tube #2-1   5400   62 mA
Tube #2-2   5600   69 mA
GENERAL TERMS AND CONDITIONS – PLEASE READ CAREFULLY
I hate to put all these conditions in this listing, but in today’s climate it is necessary.  Also, if you have not figured it out from the language, I am a lawyer in real life.  If it turns out that there is a misdescription in my listing, I will work with you for an appropriate resolution.
For those people who do not read my listing or with unreal and unreasonable expectations, I want to make the following clear.
THESE TUBES ARE BEING SOLD “AS IS, WHERE IS”.
ALL SALES ARE FINAL.
I ONLY describe what I know about the tube, and what I have tested for.  Although my tube testers tend to be reliable, YOUR TUBE TESTER MAY GIVE A DIFFERENT RESULT THAN MINE, so please take that into account. In the event of a tube tester conflict, MY TUBE TESTER CONTROLS.
If the information is not there, DO NOT ASSUME, and do not rely on any of YOUR assumptions. If you need more information than provided in the listing, ASK IN ADVANCE. If I happen to have the information, I will provide it. If I can get the information in a reasonable way, I will get it. If I do not call a tube NOS, consider that tube USED. I do the best I can with very limited time and capabilities. I am an honest seller, but I am NOT a tube professional, and I am NOT in the tube business.
AS SUCH, PLEASE NOTE THAT I CANNOT GUARANTEE (OR EVEN REMOTELY PREDICT) HOW THESE TUBES WILL SOUND OR PERFORM IN YOUR EQUIPMENT. THE TEST RESULTS ARE ONLY PROVIDED AS AN INDICATION OF TUBE PERFORMANCE IN A VERY LIMITED (AND NON-IDEAL) ENVIRONMENT. EXCEPT AS EXPRESSLY INDICATED IN THIS LISTING, I DISCLAIM ANY AND ALL REPRESENTATIONS, WARRANTIES AND LIABILITY WITH RESPECT TO THESE TUBES, OR RESPONSIBILITY FOR YOUR USE OF THEM.
The buyer is responsible for all shipping charges (including but not limited to any customs fees, duties, import taxes and related charges).
Shipping will be via USPS Priority Mail unless otherwise requested.
I WILL NOT FALSIFY INFORMATION ON A CUSTOMS FORM.
For all shipping, the terms are EXW US Post Office (INCOTERMS 2010).  In accordance with these terms, I will deliver the lot into the possession of the US Post Office, and once in the possession of the US Post Office ALL RISK OF LOSS PASSES TO THE BUYER.
WHAT THIS MEANS IS THAT I EXPRESSLY DISCLAIM ANY AND ALL RESPONSIBILITY FOR DELIVERY (INCLUDING BUT NOT LIMITED TO DAMAGE OR LOSS) BY ANY POSTAL SYSTEM, AND BY PURCHASING THIS LOT YOU EXPRESSLY WAIVE THE RIGHT TO FILE A CLAIM (INCLUDING BUT NOT LIMITED TO BUYER PROTECTION CLAIMS WITH EBAY AND PAYPAL) FOR ANY SHIPPING RELATED ISSUE.
If, however, you have purchased insurance for the item, I will assist to the best of my ability in the processing of any legitimate insurance claim you desire to file.
Cash is always welcome for a local transaction. Payment can also be via money order/cashier’s check/personal check but, except for US Postal Money Orders, all must clear my bank first.
I also accept Paypal for convenience.  IF YOU PAY VIA PAYPAL, HOWEVER, A CONDITION OF YOUR PAYMENT IS THAT YOU EXPRESSLY WAIVE THE RIGHT TO FILE A PAYPAL CLAIM OR CHARGE BACK (but do retain the right to sue me in court should you so desire).
Trade is also possible, but my needs are very limited and it would need to be a pretty good deal.  In any event, it does not hurt to ask.
Please check my feedback on Ebay (ID=baileyler) and buy with confidence.
« Last Edit: 21 Sep 2020, 11:44 pm by baileyler »
baileyler
Only Pair #1 and Pair #2 remain from the original ad.
If you want both, I would take $500.
