0 Members and 1 Guest are viewing this topic. Read 8751 times.
Help me out, am i missing something here? I see amp options on the Kickstarter but no DAC dac 3 option . Thanks
Congratulations on quickly meeting your goal! It seems like kickstarter has really become something DAC does very well!Interesting to read that this new DAC will have multiple inputs. I'm curious as to why - in spite of consistently pursuing and promoting the advantages of the shortest signal path possible - integral USB input is (again) excluded, I'm presuming in favor of leaving it outboard using the existing external converter/adapter? Have most audiophiles using external non-volume controlled DACs given up on computer-based front ends with USB output? It seems like the longest segment in the signal path on DAC DAC anymore is a few cm worth of wire with a pair of (relatively) big external connectors that connect the DAC to the USB converter. Wouldn't shrinking that connection down to maybe a cm worth of copper board traces (considering it looks like there's plenty of room on the DAC DAC board to integrate the USB converter) be the biggest bang for the buck in terms of shortening the signal path?
How about adding the 60V supply to the list
Added today!!
I am in 3 way active setup.I am considering the stereo maraschino to power my tweeters (raal 140-15d, 95db efficiency, 8 ohms).Considering will power only tweeters (2.8k+) do the x-cherry 2 still have an advantage ?Do you think I am better with 36 volts =, 48 volts or go with the king 60 volts.
Thanks Tommy, I'm on it
Tommy maybe I missed it somewhere...can you post the difference between the DACDAC3 and 3S?Thanks,Chris
3S has an input selector (coax or optical). Thanks (:
