***SOLD*** Audio GD Master-7 DAC
0 Members and 1 Guest are viewing this topic. Read 675 times.
Early B.
« on: 2 Sep 2020, 10:51 pm »
***SOLD***
For sale is an Audio GD Master-7 DAC. This incredible sounding and very versatile DAC is extremely overbuilt and sounds phenomenal. Check out the stock image of the guts below. This was Audio GD's top-of-the-line DAC a few years ago based around the PCM 1704UK chip. It has four PCM 1704UK chips per side. I purchased it brand new directly from Audio GD. This DAC is in pristine condition.
The Master-7 is a great sounding DAC. Very neutral and full sounding. This DAC has tremendous analog sound with an expansive soundstage and high resolution.
The Master 7 is the ultimate design of the PCM1704 chip. In fact, there were no design compromises. The DSP processor is soldered on the main board directly for best signal transfer and faster data processing and clocking. It brings the detail, transparency, and dynamics to another level. It allows users to hear the flaws and perfections of the source recording. It has enough inputs and outputs than you could ever dream of.  The Master-7 supports up to 32bit / 192KHz through USB and I2S input, 24bit / 192KHz through SPDIF inputs (8X or lower oversampling support). This does not decode DSD, however.
Comes with original packaging and stock power cord.
For more technical information, follow this link:   http://www.audio-gd.com/master/master-7/m7en.htm
Price is $995 plus shipping.
« Last Edit: 4 Sep 2020, 03:54 am by Early B. »
