0 Members and 1 Guest are viewing this topic. Read 641 times.
Welcome aboard!GIK (look for them here at AC) offers custom art impregnation on their panels.Recommend active monitors with multiple subs as the ideal setup. Can be done for under $3000. What's your budget?
Hmm elaborate more, I've considered H frame subs for clean, tight bass. Have not considered active monitors, was looking to use my vintage Pioneer receiver as a piece of the puzzle. I actually currently have monitors wired to the Pioneer (from a HTiB Energy take classics) and using the 8" sub in the meantime. Budget is an excellent question, as I would like this set up sooner rather then later and with the components already purchased I was looking at just needing some speakers. The DIY route seems to be the best bang for buck. CSS Audio and GR research have both caught my eye as potential options seeming for under $1,500 I could put together a truly amazing sounding front stage.
Greetings & Welcome to AC Mike
...I do more research then is probably healthy.
Ha! Yes, we’re all guilty of that...Welcome JD
