Power Supply for BDP-pi
0 Members and 1 Guest are viewing this topic. Read 975 times.
jobiwon
« on: 29 Aug 2020, 06:16 pm »
I have come upon a SGC 15W 12v linear power supply.  Will this run my BDP-Pi?  The urrent Pi  power supply indicates 25W MAX.  But dont know if that is what the Pi actually needs to operate.
joe
srb
Re: Power Supply for BDP-pi
« Reply #1 on: 29 Aug 2020, 06:33 pm »
According to the back panel power jack legend, the BDP-Pi requires 12VDC @ 2A (24W).
Your 12V/15W linear supply can only output 1.25A which most likely won't work properly.
zoom25
« Reply #2 on: 29 Aug 2020, 06:45 pm »
To operate, it may not need the max, but startup usually requires a lot of power. The BDP very well may not even boot. I always oversize my linear power supplies. Have a few Teradak, including a 12V 13A. Totally overkill, but sounds great!
jobiwon
« Reply #3 on: 29 Aug 2020, 09:38 pm »
 :duh:
Thanks for replies guys.  SGC support says the unit will power  router and switches.  If I wanted to try this thing out where would try it ?  I have the below modem/router:
https://www.centurylink.com/home/help/internet/modems-and-routers/actiontec-c3000a.html
I also have linksys velop AC3900 mesh routers.  One node is hardwired to the c3000a and one node is directly wired to the Pi.  Where in the chain would be a good place to give it a go?
edit: I just put it on the c3000a and its working but have not fired up the Pi yet.
joe
unincognito
    • bryston.com
« Reply #4 on: 30 Aug 2020, 02:46 pm »
:duh:
joe
If you don't have any bus powered USB devices connect to the BDPPi it might work, but you'd be drawing close to max current from a 15Watt supply and the BDP-Pi would likely loose power if you tried to plugin a bus power led USB device.  I would recommend finding something that is 25watts and you could also use an ac transformer style walwart as the BDP does have a bridge rectifier to allow reversal of power polarity and ac sources.  Followed by a linear regulator to produce the final 5 volt supply that the digital hardware requires.
Chris
Chris
