questions on Mini T
0 Members and 1 Guest are viewing this topic. Read 1605 times.
tcmo
questions on Mini T
« on: 28 Aug 2020, 10:08 pm »
1.  Is the tweeter ferro-fluid cooled?
2.  Will it over power a 12' x 10' room?  Even with the port closed.  Speakers will be on the 12' wall.
Thank you.
  • The Demo is Everything!
    • http://www.bryston.com
Re: questions on Mini T
« Reply #1 on: 29 Aug 2020, 09:55 am »
Thank you.
Hi tcmo
1. yes it is.
2. No it should be fine in a small room and as you say you can play with the port open or closed to allow for some flexibility.
james
I have them in one of my rooms which is only 11 by 13 on the long wall
Christo22
« Reply #2 on: 29 Aug 2020, 11:42 am »
Used to have those in a small room too.
They are great.
Can’t go wrong with the Mini Ts.
gene9p
« Reply #3 on: 29 Aug 2020, 01:17 pm »
the ports plugs  for the rear of the speakers are available from Axiom...they fit all Axiom and Bryston speakers that I have owned including the Mini T's...
tcmo
« Reply #4 on: 29 Aug 2020, 01:42 pm »
Thanks for all the replies.  Do the port plugs come with the speakers or purchased separately form Bryston or Axiom?
« Reply #5 on: 29 Aug 2020, 04:57 pm »
They are an extra but you can test and see if you need them by using a rolled-up old sock.
james
gberger
  • Check 6
« Reply #6 on: 30 Aug 2020, 05:32 pm »
James,
What is the backlog on Mini Ts ?
George
« Reply #7 on: 30 Aug 2020, 06:13 pm »
James,
George
Hi George
Depends on colour - some we have in stock.
Natural Cherry and Boston Cherry I have 1 pair of each.
james
gberger
  • Check 6
« Reply #8 on: 30 Aug 2020, 06:35 pm »
James,
Thank You!
Plan to go for the Boston Cherry
George
« Reply #9 on: 30 Aug 2020, 07:31 pm »
James,
Thank You!
George
Great - looking forward to your feedback.
james
gberger
  • Check 6
« Reply #10 on: 31 Aug 2020, 05:41 pm »
James,
Ordered them this morning via Audio Advisor. Hope they're in stock at Bryston.
George
« Reply #11 on: 31 Aug 2020, 05:48 pm »
James,
George
Great! - yes we had a pair in stock - exciting aye!!!
james
gberger
  • Check 6
« Reply #12 on: 7 Sep 2020, 06:48 pm »
James,
They arrived Yesterday! WOW!! Whoever invented the packaging did a superb job.
I have a B135c on order to drive the Mini Ts, and I'll use a BCD-3 and a Magnum Dynalab FM tuner for the music.
Cables? Bryston 10" with spades for the speakers. Bryston for interconnects.
Bryston had made me a very Happy Camper.  Thank you!
« Reply #13 on: 7 Sep 2020, 06:58 pm »
James,
That's great news - boy the Dynalab takes me back!
james
