Teac UD-501 D/A Converter - SOLD
0 Members and 1 Guest are viewing this topic. Read 705 times.
Phil A
« on: 27 Aug 2020, 01:03 am »
$525 (+ shipping and PayPal - willing to negotiate) SOLD
DAC + Headphone amp. Used sparingly over the years in secondary systems.  Only selling as I’ve simplified the secondary systems.
Double DSD, PCM 384kHz dual mono D/A Converter
•   Supports DSD 2.8/5.6MHz playback (via USB)
•   Supports PCM 32bit/384kHz playback (via USB)
•   Supports PCM 24bit/192kHz playback (Coaxial)
•   Supports up to 24bit/96kHz playback (Optical)
•   Supports DSD native playback by ASIO2.1 or DoP method
•   Exclusive driver software for Windows
•   Standard driver software for Mac
•   Asynchronous transfer mode
•   4 selectable analog filters (playback USB, DSD)
•   3 selectable digital filters (playback USB, PCM)
•   Non-integral up-conversion to 192kHz, when input signal is less than 192kHz (On/Off selectable)
•   Throughout dual monaural design from power transformer to output section
•   Two toroidal-core power transformers
•   Two BurrBrown PCM1795
•   Four MUSES8920 operational amplifier
•   Parallel buffer for RCA output
•   Power supply to USB circuit is switchable
•   Lineout circuit can be disabled when headphone is used.
•   Low power consumption (MAX 13W)
•   Auto power saving mode (On/Off switchable)
•   Display mode switchable (Show Up-conversion mode and selected filter)
•   Line out switchable (XLR or RCA)
•   Polarity change on XLR (2=HOT or 3=Hot)
•   Full metal body
•   Organic EL Display with Dimmer
•   1 USB audio input
•   2 Optical Inputs
•   2 Coaxial Inputs
•   1 Stereo RCA/XLR
•   3-polar AC socket with a detachable AC cable
« Last Edit: 1 Oct 2020, 03:52 am by Phil A »
Phil A
Re: Teac UD-501 D/A Converter
« Reply #1 on: 23 Sep 2020, 04:55 pm »
Bump
beeah
« Reply #2 on: 23 Sep 2020, 11:58 pm »
Perhaps you’ve already crossed paths, but there’s a wanted ad on CAM/USAM for this unit.
