Industry Circles
Odyssey Audio
klaus@odyssey
Interconnects, Speaker Cables for Odyssey Amps
0 Members and 1 Guest are viewing this topic. Read 1607 times.
[email protected]
Newbie
24 Aug 2020, 08:01 pm »
In addition to Gronberg wires, what brands have you found to be particularly good matches for Odyssey amplifiers?
DeeCee
Re: Interconnects, Speaker Cables for Odyssey Amps
25 Aug 2020, 01:04 pm »
I'm using what I previously used after replacing my prior amp: Cardas Cross ICs and Cardas Neutral Reference speaker cables. They match well and I found that Cardas seems to remove the "electronic halo" that I hear from a number of various cables I've listened to, so I've stuck with them over the years. If I note any weakness, it's a tendency to a warmer (or "golden") presentation that may not work for all users.
If you would like to see more detailed reviews that I made, you can check here:
https://www.audioasylum.com/reviews/Cable/Cardas-Audio/Cross/cables/82399.html
https://www.audioasylum.com/reviews/Cable/Cardas-Audio/Neutral-Reference/cables/124814.html
Happy Listening!
DeeCee
hi_watt
Reply #2 on:
25 Aug 2020, 02:39 pm »
So far my DH Labs Air Matrix RCAs have been good to me, even though the rest of my set up is fitted with cable from Audio Envy.
Delta77
Reply #3 on:
25 Aug 2020, 04:27 pm »
Been using Dave's RCA Cables lately..
Also used Cullen Cable (crossover line) , and Decware ..
They all seem to work well, but the Zenwave cables do appear to be the most musical (not by leaps and bonds)..
A_shah
Reply #4 on:
25 Aug 2020, 08:29 pm »
Try Wywire.com "Blue "excellent value , excellent dynamics, clean, low noise floor, completely neutral, " Absolute Sound" editors choice awards 2020 , as an alternative would try "Audio Envy " although I find the Audio envy cables to be bit heavy on the bass. I personnely prefer neutral cables , IMHO cables should not have any signatures of their own !
Asghar
golfugh
Dead Can Dance - Into the Labyrinth
Reply #5 on:
25 Aug 2020, 08:34 pm »
Gregg Straley Reality Cables
http://www.realitycables.com/index.html
genjamon
Reply #6 on:
25 Aug 2020, 08:47 pm »
Zenwave D3 RCA's are the right mix of warmth and transparency for me. D4's are too much of a good thing.
Cerious Technologies Matrix power cords and speaker cables make up the rest of the system.
Industry Circles
Odyssey Audio
klaus@odyssey
