quick oneac ?ion
0 Members and 1 Guest are viewing this topic. Read 932 times.
GefellTaper
quick oneac ?ion
« on: 2 Mar 2005, 03:02 am »
I got the cheapest oneac unit I could off of ebay and quite frankly, it sounds pretty good.  It is a rebadged oem product, and the case it came with is attached in a way that I can't for the life of me figure out how to get it off.  There are no screws, just round metal fasteners of some sort.  Any ideas?
Sorry if this is really dumb!
Daryan
Wayne1
quick oneac ?ion
« Reply #1 on: 2 Mar 2005, 03:10 am »
The case is probably riveted on. You will have to drill out the rivets and find some self tapping screws to replace them with.
