Using the Omnia WR-1 via a laptop
0 Members and 1 Guest are viewing this topic. Read 3126 times.
A_Man_Named_Gray
« on: 22 Aug 2020, 01:41 pm »
Hi,
thanks very much for accepting me in the AudioCircle.
I got a question already:
I recently bought the Omnia WR-1 streamer. Now I'm wondering about the best way to connect it to an Asus Zenbook, so I can make use of the Omnia's streaming abilities. I'd like to make sure that I get the real 24/192 HighRes resolution via Qobuz Studio, which I have subscribed to.
My idea would be to buy an external soundcard that connects via USB to the computer and via Optical out/in to the Omnia. But I'm not really sure. I'd really appreciate any suggestions.
Thank you very much in advance.
Gray
rustydoglim
Re: Using the Omnia WR-1 via a laptop
« Reply #1 on: 23 Aug 2020, 05:42 am »
Omnia WR-1 is meant to be a companion product to a full featured DAC or integrated amp or active speaker.
In your case, do you have a DAC to connect to your laptop? Is WR-1 your entire audio system other than amp ?
A_Man_Named_Gray
« Reply #2 on: 23 Aug 2020, 08:52 pm »
Hi rustydoglim,
thank you very much for your answer.
Simply said, I replaced a fm-tuner with the Omnia WR-1 in a very traditional "vintage" (Luxman, JBL) set up (preamp, poweramp, speakers). I remote control the Omnia via my iPhone. This setup works quite fine. I have the Spotify-app and the Qobuz-HiRes-App on the phone.
Furthermore I'd like to connect a laptop to the Omnia, because the computer-app of the Qobuz-service allows you to make sure that you really listen to HiRes-files. The Omnia won't show the resolution-data in its display. It shows which song is playing and that's that.
Hence my question in my first post.
Thank you once again.
rustydoglim
« Reply #3 on: 24 Aug 2020, 04:17 pm »
You need to wait for WR-2.  WR-1 as an entry level streamer, lacks the USB audio input.
A_Man_Named_Gray
« Reply #4 on: 24 Aug 2020, 10:25 pm »
rustydoglim,
thank you once again for the answer.
Do you know when the WR-2 will come out? Probanly I will have to sell the WR-1 then.
Kind regards,
Gray
rustydoglim
« Reply #5 on: 27 Aug 2020, 09:53 am »
Probably before end of the year. The Stream-9 has higher priority (I know you need WR-2 for the analog output and built-in DAC)
A_Man_Named_Gray
« Reply #6 on: 1 Sep 2020, 12:02 am »
Thanks. Sounds promising.
HEGOM
« Reply #7 on: 18 Sep 2020, 11:04 am »
Hi all,
This means the new MR will be able to connect directly to a usb hard disk?
rustydoglim
« Reply #8 on: 22 Sep 2020, 08:44 pm »
Yes.
giordy60
« Reply #9 on: 16 Nov 2020, 01:50 pm »
hi Jason
what are the technical characteristics of the streamer-9?
giordy60
« Reply #10 on: 16 Nov 2020, 04:10 pm »
so on the WR-2 there will be the usb input?
will the coax output always be 16 / 44.1? or will it be superior?
rustydoglim
« Reply #11 on: 17 Nov 2020, 10:07 pm »
Stream-9 has 24bit/192kHz streaming and outputs to I2S/Optical/Coaxial for connecting to DAC-9SE.
Stream-9 does not have analog output because it doesn't have built-in DAC.  It is a streaming transport for the 9-series.
For the AMG series, we might include the DAC and streaming together.
Will there be a WR-2, it is not clear at this point.
mresseguie
« Reply #12 on: 30 Nov 2020, 06:08 am »
Jason,
Can the Stream-9 connect to any DAC so long as it accepts I2S/Optical/Coaxial?
Michael
rustydoglim
« Reply #13 on: 4 Dec 2020, 11:42 pm »
Yes, but I2S is not an industry standard so check the pins specifications.
