Running KT-77s in the Ultravalve
0 Members and 1 Guest are viewing this topic. Read 1904 times.
audiomaniac
« on: 18 Aug 2020, 07:12 pm »
Hi all,
First and foremost, I hope everyone is staying safe and well in these crazy times.
I have a quad of Gold Lion KT-77s and I thought I would try them in my Ultavalve. They are not that old and probably have less than 100 hrs on them. Anyway, they sound pretty good. But after I set the bias and ran them in a little, the most I can get out of them is around 1.35v. They replaced some EH 6CA7s that I was easily able to set around 1.5v. My other tubes are Sylvania 6GH8As and a Sovtek 5AR4. I do not know the age of the tubes other than the KT-77s.
My question is if this is normal for KT-77s to bias so much lower and also do they put out less power than 6GH8A/EL34 tubes? Is it possible that the Sovtek 5AR4 is getting weak and not allowing me to be able to set the bias higher on the KT-77s? I never like running anything flat out but that's what I'm pretty much doing with the KT-77s.
Lefty052347
  • AVA Associate
Re: Running KT-77s in the Ultravalve
« Reply #1 on: 19 Aug 2020, 05:16 am »
After going through 2 sets of 6ca7's, I tried a set of KT-77's.  I had no problems with them but went back to 6ca7's due to cost.  I didn't think the KT-77's were worth the extra money.
I ran the bias between 1.4 and 1.5 volts.
I have had my Ultravalve for over 10 years.
Dean
audiomaniac
« Reply #2 on: 19 Aug 2020, 05:29 am »
Dean
Hey Dean, thanks for the info. Yeah so I guess something is off with my amp if I'm only pushing 1.35v wide open. I might check with Frank but I'm thinking the rectifier tube might need to be replaced.   :(
John
avahifi
    • http://www.avahifi.com
« Reply #3 on: 19 Aug 2020, 03:28 pm »
Your issue is either a low output 5AR4 rectifier tube or a set of out of spec low gain KT77 output tubes.  Replace the 5AR4 first.
Frank
audiomaniac
« Reply #4 on: 19 Aug 2020, 03:51 pm »
Thanks Frank!  :thumb:
John
avahifi
« Reply #5 on: 19 Aug 2020, 08:04 pm »
Make sure you get a real 5AR4 tube.  There are rebranded fakes out there, usually with smaller glass envelops.
audiomaniac
« Reply #6 on: 19 Aug 2020, 08:10 pm »
Will do.
audiomaniac
« Reply #7 on: 21 Aug 2020, 10:42 pm »
Well, it turned out to be the KT77s. I got a nice new 5AR4 though. Back to the 6ca7s. So much for my big tube adventure!
pehare
« Reply #8 on: 21 Aug 2020, 10:51 pm »
How do you like the amp?  I've always wondered how the Ultravalve sounds I've never even heard a ST70
audiomaniac
« Reply #9 on: 21 Aug 2020, 10:55 pm »
I absolutely love this amp! It's very robust and sweet sounding. If I could run it mono I'd buy another one.
