Aerial Acoustics 7T *SOLD*
0 Members and 1 Guest are viewing this topic. Read 1030 times.
Ledhead26
« on: 16 Aug 2020, 04:50 pm »
Up for sale are my Aerial Acoustic 7T speakers. These are in excellent shape both cosmetically and functionally. They are in the gloss rosenut finish and are truly beautiful. The Aerials sound fantastic and truly compete with speakers much more expensive than themselves.
Specs:
Frequency Response: 28Hz to 25kHz ±2dB, -6dB at 23Hz
Dispersion: 30Hz to 15kHz +0, -3dB from axial response 45 degree horizontal measurement window
Sensitivity: 89dB for 2.83 volts at 1 meter on axis
Impedance: 4Ω nominal, 3Ω minimum, low reactance
Power Requirement:  25 watts minimum, 100 or more recommended
Woofers: Twin 7.1″ (180mm) with cast magnesium frame, rigid bilaminate composite cones, large magnets, 1.5″ coils, long and linear Xmax
Midrange: 5.9″ (150mm) with cast magnesium frame, special Papyrus blend cone, copper pole sleeve, dual magnets1.25″ coil, long and linear Xmax
Tweeter: 1.0″ (25mm) with thick machined aluminum plate, soft ring-dome design with machined wave guide, dual magnets, 1.0″ coil, copper pole sleeve
Crossovers: Fourth order acoustic Linkwitz-Riley at 400 Hz and 3,000 Hz crossover frequencies, 2 physically separate networks on glass-epoxy PCBs, bi-wirable and biampable, high-purity copper wiring and silver solder, premium passive components
Cabinet: 9 layer laminated, curved, stressed MDF walls, 7 interlocked full-size braces, tongue and groove joints, 2-piece curved and damped baffle, architectural veneers
Finishes: Gloss Rosenut, Nero Metallic Black
Grille: Cloth covered curved steel with hexagonal windows, 8 Neodymium magnets, no visible mounting hardware
Dimensions HWD :44.5 × 9.7 × 15.3″ (1130 × 245 × 390mm)
Weight :Each 96lbs (44kg) – 154lbs (70kg) packed
I do not have the boxes so local pickup is preferred. If someone is willing to set up crating/shipping these I am willing to go down that road as well. I’m located in MD 21921 pretty much right between Baltimore and Philadelphia. Asking $6000 or best offer.
« Last Edit: 17 Sep 2020, 12:03 am by Ledhead26 »
Ledhead26
Re: Aerial Acoustics 7T
« Reply #1 on: 27 Aug 2020, 12:34 pm »
Price drop to $5800
Ledhead26
« Reply #2 on: 3 Sep 2020, 08:07 pm »
Price drop to $5500 obo
Ledhead26
« Reply #3 on: 10 Sep 2020, 12:07 pm »
Final price drop to $5100, these beauties need a new home
