Hum in Khartago mono amp
0 Members and 1 Guest are viewing this topic. Read 1288 times.
esus1
« on: 14 Aug 2020, 01:49 pm »
This is my first year of owning the Khartago mono amps. They have been great. I recently noticed that one of them has a hum that is coming from the speaker. No matter where I plug (AC) the symptom does not change. The other identical mono amp has no noise when plugged into the exact same outlet. The preamp feeding them is a Schiit Saga and it is  turned off.
Any ideas on what this may be?
All thoughts are appreciated.
Speedskater
  • Kevin
Re: Hum in Khartago mono amp
« Reply #1 on: 14 Aug 2020, 01:58 pm »
Did you try using other interconnect cables?
Did you try swapping interconnect cables Left to Right?
Is everything plugged into the same AC mains outlet?
esus1
« Reply #2 on: 14 Aug 2020, 02:05 pm »
Hello Thank you for the advice.
I just now determined that a line from the preamp was the culprit eventhough the preamp was turned off.
I disconnected it and the problem is gone.
That line was going to a sub from the preout. I will track this down now that its beend isolated.
Thanks again!
steverii
« Reply #3 on: 16 Aug 2020, 12:04 am »
I know this goes against all the safety rules, but I have often had to use a "cheater" plug on the powercord going to the sub to remove hum.
