When to upgrade?
0 Members and 1 Guest are viewing this topic. Read 1262 times.
Zyphryx
When to upgrade?
« on: 12 Aug 2020, 08:37 pm »
I changed speakers from PSB X2Ts to Focal Aria 948s. The 948s have an efficiency of 95db as opposed to PSBs which had 88 or something like that. Question is, do I need to send the amps back in to have the bias tweaked or is this not worth the effort?
klaus@odyssey
Re: When to upgrade?
« Reply #1 on: 12 Aug 2020, 09:33 pm »
No,  you're ok......rebias is more needed if there's a big change in your house voltage and / or if you change from / to either a really dark or bright speaker..........
Zyphryx
« Reply #2 on: 13 Aug 2020, 09:58 am »
Good to know. Thanks Klaus.
