audio acoustic speakers
0 Members and 1 Guest are viewing this topic. Read 1004 times.
cricket2386
« on: 10 Aug 2020, 11:31 am »
hi all
I have a pair of older audio concepts super titan speakers  and want to get the foam repaired on them
Aci was one of the best speakers in the 90 s
I made these as a kit  an I am the original owner
I am retiring  an want to replace the foam on them to sell them off or maybe I will still keep them they are great.
The kit then was over $1000 dollars  (1990)
  and I am told today they are still wanted
these speakers are fantastic but I need some information on fixing them
has anyone done this on aci speakers?
Re: audio acoustic speakers
« Reply #1 on: 10 Aug 2020, 11:32 pm »
Hi
Whats do you mean say by foam?
The inside stuffing or the cone foam surround?
dB Cooper
« Reply #2 on: 10 Aug 2020, 11:49 pm »
Tweeter looks hosed (crushed). Replacements might be made of unobtainium. I'd find out about those first (I use the plural because they should probably be replaced as a pair.) If suitable new tweeters are available, then the surrounds may be worth doing.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #3 on: 11 Aug 2020, 12:00 am »
If it is Audio Concepts by Mike Dzurko, I suggest you post your query here:
https://www.audiocircle.com/index.php?board=76.0
Best,
Anand.
