Can the B60 drive the Mini A speakers?
0 Members and 1 Guest are viewing this topic. Read 749 times.
gberger
  • Check 6
« on: 21 Jul 2020, 03:36 pm »
I'm setting up a two channel system in the guest bedroom. I already have a B60, with a Magnum Dynalab  FM tuner for the music source.
Given the fact FM stations use dynamic compression, so that a listener only has to set the volume at the beginning of a broadcast, can the B60 effectively drive a pair of Mini A speakers at low to medium volumes?
The speakers will be mounted on small pedestals.
TIA for any thoughts.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Can the B60 drive the Mini A speakers?
« Reply #1 on: 21 Jul 2020, 08:20 pm »
Hi G
Yes the B60 with the Mini A's will work just fine in that setup. I have the same setup in my office and listen to internet radio all day!
james
gberger
  • Check 6
« Reply #2 on: 22 Jul 2020, 12:13 am »
Hi James,
Thank You!  Much relieved to hear it..
George
