Recommendation please
0 Members and 1 Guest are viewing this topic. Read 2081 times.
depoca
« on: 19 Jul 2020, 02:04 am »
New member asking the following question:
Cannot which of two speakers to choose from: Bryston Mini A or Mini T. My room is 13 x 16ft.
I play mostly classical and jazz. The amplifier would be a Bryston B135.
Any recommendations?
Re: Recommendation please
« Reply #1 on: 19 Jul 2020, 02:54 am »
Welcome  :thumb:
I will move this topíc to the Bryston Circle.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 19 Jul 2020, 10:29 am »
Hi depoca - welcome.
james
Phil A
« Reply #3 on: 19 Jul 2020, 01:18 pm »
 Welcome!
« Reply #4 on: 19 Jul 2020, 01:19 pm »
Hi
Do you have a preference for a Stand mounted speaker rather than a Floor mount?
james
depoca
« Reply #5 on: 21 Jul 2020, 02:30 am »
Yes I would prefer  stand mounted speakers.
As an aside, is there a DAC card option for a B135 that would accept USB?
« Reply #6 on: 21 Jul 2020, 10:34 am »
Hi depoc
No the DAC will only accept Optical or COAX.
james
depoca
« Reply #7 on: 21 Jul 2020, 12:47 pm »
So coming back to my earlier topic....Bryston Mini A versus Mini T.
Is there an appreciable difference between them if music is played and low to medium levels?
And would you know if the onboard DAC for a B135 would be of comparable quality than the one commonly found in streamers?
« Reply #8 on: 21 Jul 2020, 02:37 pm »
HI
The Mini T is really a different performance level than the Mini A.  So I would assume your decision would be based more on room size, levels you play at and budget. Small speakers like the Mini A are great at presenting a sound stage outside the speakers itself and will not excite the low bass room nodes that a larger speaker like the Mini T is capable of.
The DAC in the B135 is the same quality as out outboard units so much superior to most streaming style DAC's.
james
depoca
« Reply #9 on: 11 Sep 2020, 02:20 am »
James
Is there a Dealer in Montreal that carries either the Mini A or T that I could listen to?
gberger
  • Check 6
« Reply #10 on: 11 Sep 2020, 02:42 am »
I have both pairs of speakers
Use the Mini A speakers with a B60 integrated and an FM tuner for sound. It's in the bedroom, and does a very nice job on FMs 24/7 classical selections at a moderate volume.
I'll use the Mini T speakers with a B1235 integrated in my office / den where I can jack up the volume to decent hearing levels  - - again, using a classical FM station for music.
I temporarily placed the Mini Ts in my primary system form a break-in (BCD-3 spinner, BP17c preamp, 4Bcubed amp.)
 I'm truly impressed with those speakers. "Mini sound?" Nah! Down to the mid to lower 30s bass and wonderfully clear highs.
Hope this helps
George
« Reply #11 on: 11 Sep 2020, 11:44 am »
James
I will ask the Rep
james
