Poll
Should I downgrade from a Modwright SWL9.0SE preamp to a musical AVR as preamp
No way! It'll make a huge difference
6 (85.7%)
Try it, it may just be acceptable
1 (14.3%)
Should be barely noticeable
0 (0%)
Total Members Voted: 7
Downgrade from dedicated preamp to AVR as preamp (long post, need help)
0 Members and 1 Guest are viewing this topic. Read 2761 times.
musicgeek
Thanks everyone for your help! Decided to stick with 2 channel for now :) Might kick in an additional sub for movies, but will wait to see how the system sounds first!
A_shah
You may want to try get a Denon AVR- 3700H or 3600H you can turn of the amps on both these units and use it as a pre -pro with a external 5/7 channel amp.  if you wait until November  ( Black Friday) you could probably pick one up for less than $ 800.00 but again it won't match the SQ quality of the Modwright or a 2 channel system getting subs is always a good idea if you can swing it get a REL t/9i or a pair of  T/7i  the subs. :thumb:
Asghar
