Before calling Klaus
0 Members and 1 Guest are viewing this topic. Read 2497 times.
WarmColors
« on: 17 Jul 2020, 08:24 pm »
Hi all,
This will be my first time placing an order for a "custom" amp.
I emailed Klaus yesterday asking what information he needs, specifically speaker I will be using.
Is Klaus looking for crossover point? Or what information has he asked you when you placed your order?
Thank you.
GentleBender
Re: Before calling Klaus
« Reply #1 on: 17 Jul 2020, 10:56 pm »
He normally asks what speakers you have and other components along with asking for to check voltage over a few days at different times. He is fun to talk to so make some time and call after 8pm.
WarmColors
« Reply #2 on: 18 Jul 2020, 01:41 am »
Check voltage really that in depth?
Does he ask about crossover points?
« Reply #3 on: 18 Jul 2020, 02:39 am »
Klaus will adjust the amp to your speaker, what are interesting to consider is if this your current speaker is a definitive speaker in your life, since Odyssey amps will lasts decades or more.
DeeCee
« Reply #4 on: 18 Jul 2020, 04:00 am »
He didn’t ask about crossover points in my case. Line voltage is used to set bias for the amplifier (a nice touch you don’t find from many manufacturers.)
WarmColors
« Reply #5 on: 18 Jul 2020, 04:15 am »
Again sorry for my ignorance, but again I'm new to the "custom" amp aspect. How do I check line voltages?
DeeCee
« Reply #6 on: 18 Jul 2020, 04:25 am »
You can check using a multimeter or a voltage checker. You can find basic cheap meters on Amazon and other sites.
WarmColors
« Reply #7 on: 18 Jul 2020, 04:31 am »
I have one in the garage.
What would you recommend. Check it three, four times every 3 hours and get the median?
DeeCee
« Reply #8 on: 18 Jul 2020, 05:00 am »
I checked a couple or 3 times a day fairly randomly: usually at my prime listening time. I simply averaged over several days. My power was pretty consistent. I averaged it.
« Last Edit: 19 Jul 2020, 01:29 am by DeeCee »
WarmColors
« Reply #9 on: 18 Jul 2020, 08:48 pm »
I checked a couple of times a day fairly randomly: usually at my prime listening time. I simply averaged over several days. My power was pretty consistent. I averaged it.
Lol. I just realized what I wrote. Check 3-4 times every 3 hours? Lol. I would be checking every hour.
I've been checking every 3 hours. I've turned everything on around the house for a heavier system load and I am impressed I keep getting fairly consistent readings.
« Reply #10 on: 18 Jul 2020, 09:59 pm »
For those living in a building its useful discover how big is the building transformer if it have one dedicated, my condo use a in house 225KVA transformer, input is 13.800V output are 127V x three.
If the transformer are too small one could expect low quality mains.
« Last Edit: 19 Jul 2020, 01:21 am by FullRangeMan »
liptrader
« Reply #11 on: 19 Jul 2020, 05:26 pm »
I use a Furman M-8Dx power conditioner that display the voltage 24/7. Also you get spike protection and a a convenient e
Way to plug all your equipment there. And 2 front lights if you care.
