Techs
0 Members and 1 Guest are viewing this topic. Read 716 times.
drummermitchell
Techs
« on: 16 Jul 2020, 11:40 pm »
Hoping bryston techs are back to work or no.
lost both USB Ports on new BDA-3.
played some tracks and they both QUIT.
Computer,preamp,amps are 100%BDP-2 is also working.
want to kow if the techs or some are back at work,
THX
PS:did the normal plug /unplug usb whatever same thing.
AES digital worked great for about an hour and FK,done.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Techs
« Reply #1 on: 17 Jul 2020, 01:04 am »
Hi Drummer
Well that's a new one on me?
Anyway send the info to Mike please - [email protected]
james
drummermitchell
Re: Techs
« Reply #2 on: 17 Jul 2020, 01:31 am »
Thx James,
Will phone tomorrow as emails at times are unanswered(sorry).
I’m amazed where usb can really effect certain components in the audio chain(sub)
Found that out switching to AES digital,let alone checking all wiring and connectors ect blah blah.
Anyway thanks I’ll give a shout tomorrow.
drummermitchell
Re: Techs
« Reply #3 on: 17 Jul 2020, 02:38 pm »
Now that I’ve cooled off a bit,I phoned Bryston and Mike is off today(not a big deal).
So disconnected everything on the dac to see if perhaps a loose connection inside.
All seems good there.
So reconnected the dac and same thing:
Usb+1 and 2 light up no sound.
AES I get sound.
I do find it odd that say if you unplug the dac’s PC that the usb cable you have to unplug and reinsert to get the led to light up.
The AES cable I do not have to.
Anyway off to Audioark tomorrow to home audition a BP-17 cubed so will take the dac in and send her off.
Now I have to resort to playing cds again,Oh the misery.
Re: Techs
« Reply #4 on: 17 Jul 2020, 03:16 pm »
AES I get sound.
Hi Drummer OK let me know the results.
james
