SOLD Line Stage Preamplifier W/Remote - Balanced [XLR] & RCA - $1175.00
0 Members and 1 Guest are viewing this topic. Read 514 times.
undertow
SOLD
Features:
• Zero-feedback, fully balanced discrete circuitry
• Tape loop, or HT bypass RCA
• Sixty-six step volume control, 1.0 dB increments
• Four inputs: two balanced, two single-ended
• Two Stereo ouputs: 1 XLR, 1 RCA
• Proprietary volume control employs precision metal film resistors
There are some light scuffs on the top plate which are easily removed by taking top plate off lightly sanding out as it is just raw silver aluminum, and it will come out perfect I just never wasted the time honestly as in a shelf it never bothered me.
There is a scratch on the back panel that looks to be a rca jack, or power cable dropped against it type incident, but completely insignificant.
I have reflected the blemishes in the low pricing.
Dimensions: 17.25" (440mm) W by 4.75" (120mm) H by 13.75" (350mm) D. Weight: 25 lbs (11.5kg).
No original box, but will be packaged safely for Fed Ex.
I will supply original manual, original Ayre remote, standard IEC power cable.
« Last Edit: 14 Jul 2020, 09:39 pm by undertow »
undertow
