Best Tube amplifier for $1000 or less?
0 Members and 1 Guest are viewing this topic. Read 6436 times.
chgolatin2
« on: 8 Jul 2020, 02:49 pm »
Best tube amplifier for the money $1000 or less?  Not sure if this is even realisitc but I'm looking to explore.  Also, it needs to put out 30 to 60 watts  :scratch: Point to Point no PCB's... GO!
Freo-1
Re: Best Tube amplifier for $1000 or less?
« Reply #1 on: 8 Jul 2020, 02:53 pm »
Look for a Fisher KX 200.
HT cOz
« Reply #2 on: 8 Jul 2020, 04:33 pm »
I have one for that price target
It's been sitting in my closet for 10 years.
RDavidson
« Reply #4 on: 8 Jul 2020, 08:06 pm »
I had a Cayin A50T a long while back. Very well built ; Same folks that build Primaluna (another great option). I found the A50T to have "classic" EL34 sound and presentation, but with the convenience of remote control. Tube biasing is also very easy and I want to say they even supplied a test meter with the amp. Neat.
billion$baby
« Reply #5 on: 8 Jul 2020, 08:15 pm »
  I have a Wilsenton R8 BRAND NEW in the Box mentioned above. Could use the extra space so if your interested LMK. Will be well under 1K with Free FedEx Delivery.
timind
  • permanent vacation
« Reply #6 on: 8 Jul 2020, 08:44 pm »
 Of the tube amps I've owned, the Fisher KX-90 is the only one I would recommend from experience. If I ever get another tube amp it'll be a vintage Fisher or Scott.
Freo-1
« Reply #7 on: 8 Jul 2020, 09:08 pm »
Fisher and Scott are both good choices.  My experience with the KX-200 is why I recommend it.
Letitroll98
  • Too loud is just right
« Reply #8 on: 9 Jul 2020, 11:25 am »
Some great suggestions, but apologies to our dear member, the op is way over guidelines for C&C.   We'll move it over to the Tube-o-phile Circle for you.
Ericus Rex
« Reply #10 on: 8 Aug 2020, 12:38 am »
Quicksilver GLA is my rec as well.  I've had one for over 10 years now.
Chaplir
« Reply #11 on: 29 Nov 2020, 08:13 pm »
Hello, do you still have the Wilsenton R8 ?
