Opinion - Kaiu Record Cleaning Set
0 Members and 1 Guest are viewing this topic. Read 3019 times.
Sonny
« on: 4 Jul 2020, 03:27 pm »
Hi, has anyone experience with this kit? I really could use a new brush and stylus cleaner, that's really it.
https://smile.amazon.com/Vinyl-Record-Cleaning-Kit-KAIU/dp/B07H5C8ZL2/ref=sr_1_3?crid=2VOJMKEFNAU0Z&dchild=1&keywords=kaiu+record+cleaning+kit&qid=1593837117&sprefix=kaiu%2Caps%2C220&sr=8-3
Opinions or feedback?
Thank you!
orthobiz
Re: Opinion - Kaiu Record Cleaning Set
« Reply #1 on: 4 Jul 2020, 08:09 pm »
Even though I have no experience with it, doesn't stop me from rendering an opinion.
Looks like too much for too little.
Paul
Sonny
« Reply #2 on: 4 Jul 2020, 08:50 pm »
Paul
Paul, thanks.  So you think for $29 to get two brushes, stylus cleaner and record cleaning solution is too much?  Please so me where I can get a good stylus cleaner like Last or Mofi, which are $30 a bottle?
T
toocool4
« Reply #3 on: 4 Jul 2020, 09:25 pm »
Sonny give them a try, looks like good value for money.
I use Furutech's SK-III anti-static brush, now that is over priced.
https://www.thecableco.com/sk-iii-anti-static-record-brush.html
Sonny
« Reply #4 on: 4 Jul 2020, 09:27 pm »
I just might.  I currently use an Audioquest Anti-Static brush.  I just need some new Stylus cleaner like last or Mofi, but can't believe it's $30 a bottle!
toocool4
« Reply #5 on: 4 Jul 2020, 09:37 pm »
For my stylus cleaning i use 2 things. DS Audio’s ST-50 and Flux Hifi Sonic.
I use the ST-50 after each side and the Flux at the end of every listening session.
https://www.thevinyladventure.com/product/ds-audio-st-50-stylus-cleaner/
https://www.analogueseduction.net/stylus-cleaners/flux-hifi-sonic-electronic-stylus-cleaner.html
Sonny
« Reply #6 on: 4 Jul 2020, 11:06 pm »
Thanks!  I use the ONZOW after each record and last every few records.  Once in a while, I'll use the stylus brush to get tough grime out. I used to use the Mr. Clean Erasure but am always afraid the stylus or cantilever will catch.
T
Letitroll98
  • Too loud is just right
« Reply #7 on: 5 Jul 2020, 06:44 pm »
Sticky Hands toys are the same gel as Onzow and other stylus cleaners and costs pennies instead of $69 or whatever they're selling it for now.
The liquid and brush cleaners are okay for maintenance cleaning, but don't get out all the grime.  For $29 it seems like a good deal for what you get.  For deep cleaning I use a three step enzime cleaner and rinse with a vacuum machine.  After that nothing but a good anti static brush is needed.
Sonny
« Reply #8 on: 5 Jul 2020, 07:34 pm »
Thanks for the note on the sticky stuff!  I bought the Onzow years ago, still works today. Just wash with soap and reuse.
I just need the stylus solution like Last or Mofi, but there must be a DIY recipe for it, no?
