Simple DIY Audio Rack
0 Members and 1 Guest are viewing this topic. Read 1819 times.
arif
« on: 2 Jul 2020, 04:45 am »
I was encouraged by other posts from this forum, so I thought I would share it.
https://www.youtube.com/watch?v=D25E2FPxL4g
sunnydaze
Re: Simple DIY Audio Rack
« Reply #1 on: 2 Jul 2020, 05:45 pm »
Nice job....thanks for the video!   :thumb:
Similar to how I built mine except I went with double width BB, and didn't use any cross members or vibration / isolation devices.   Just (4) 80-20 uprights and BB shelves bolted solidly onto L brackets.  Top shelf is wider than rest and bolted down into 80-20 threaded center channel - no L brackets.  For levelling and sliding across the floor, I screwed hex bolts into bottom of 80-20 posts and glued some sliders onto bolt heads.
I have since modified it into 3 shelves by cutting down the uprights and removing one of the shelves.
