5V opamp?
0 Members and 1 Guest are viewing this topic. Read 1286 times.
Jan F
    • http://www.thielesmall.com
5V opamp?
« on: 26 Feb 2005, 01:25 pm »
Hi,
Anyone have an idea of a good opamp for a preamp / input buffer that runs well of 5 volts?  Most opamps run best on +/- 12V or higher and preformance data is not really available for 5V even if some are specified to run down to this voltage. In my case I need to run on a +/- 2.5V or 0 / +5V.......
markC
5V opamp?
« Reply #1 on: 2 Mar 2005, 09:49 pm »
Don't know if you need a dual or a mono, but I ran across the AD826AN, (a dual),  in my research and it's specs look good @ 5v. They probably have a mono version or at least a similar one.
Jan F
5V opamp?
« Reply #2 on: 3 Mar 2005, 02:41 pm »
Thanks for the input.
I need a dual so its perfectly OK and I will take a look
