X-Statik Crossover Upgrade - .1 microfarad Sonicap
0 Members and 1 Guest are viewing this topic. Read 2066 times.
Ben Toskey
« on: 27 Jun 2020, 07:55 pm »
Hey Guys- I am mostly done upgrade my X-Statik Crossover. The (1) component left is the .1 mf Sonicap. I'm not too handy with electrical diagrams, so I'm a bit confused about where to place it.
Do I put it across C1-C2 and keep the other components present? Any explanation or a pic would be very helpful!
Here is the whole board in its current state
Here is the component in question held above the suspected installation point.
Danny Richie
Re: X-Statik Crossover Upgrade - .1 microfarad Sonicap
« Reply #1 on: 28 Jun 2020, 01:12 am »
That cap just by-passes those two caps in your picture.
You can just twist them onto the 20uF ply cap and solder them on.
Ben Toskey
« Reply #2 on: 28 Jun 2020, 09:22 am »
Thanks for the speedy answer Danny! Really appreciate all of your help throughout this project.  :thumb:
GaryPC
« Reply #3 on: 2 Aug 2021, 12:43 pm »
That bypass cap is so small I installed mine on the back side of the pc board
zoso124
« Reply #4 on: 20 Sep 2022, 08:28 pm »
That was a smart idea Gary. I did that myself!
