Martin Logan Source Speakers Immaculate Condition - Grotto Subwoofer Optional
0 Members and 1 Guest are viewing this topic. Read 517 times.
nurxhunter
SALE PENDING on Source. Grotto sub is available  Thanks everyone for interest.  $725 IS FOR SOURCE SPEAKERS ONLY. GROTTO SUB IS OPTIONAL at $350. LOCAL PICKUP 19380 ONLY. Or, you can pay and arrange for U-Ship or other shipping. As a second owner, I never have rated anything over 8/10; but these are in such perfect condition I will break my rule. They truly look as new.
Martin Logan CLS Source. Do a deeper Google dive and read the remarkably uniform praise for these Martin Logan Source panel electrostatic speakers. Hybrids with cone woofers that integrate quite nicely with panels. Always kept covered. Vacuumed with a Kirby G4 ('nuff said) horsehair brush very carefully, LIGHTLY and gently several times per year, although they did not need it because I have electrostatic air filters on furnace/AC system and due to allergies always use filtered air in the house year round.
Pet-free, kid free, smoke free, dust free home. The tilt-able bases allow the vertical angle to be set for seated or standing listeners. A very cool idea and can be used with or without the original spikes.
I do not think you will ever find a nicer pair than these Martin Logan Source CLS electrostatic hybrid speakers in this ad! I will be sad to see them go, but I have not used them in a year. They have been sock-stored in my living room, displaced by Merlin VSM-M speakers I picked up locally. They are ready to be picked up at the front door.
My 15W Cyrus Brenneman Stereo-15 EL84 amplifier drove them fabulously in a 13' X 18' X 8' living room open to dining room. So much so, that I did not feel I needed the Grotto subwoofer, in fact, guests at first did not believe the powerful lows coming from the Source were WITHOUT the subwoofer on. But, if you take time and attention, the Grotto will blend in just marvelously and seamlessly. For Rap/RnB/HH music, a sub is almost always helpful, of course.
Grotto is available separately for $375 and I can do a deal if someone buys both--picked up at front door.
The platform they come with is unique in that by just twisting the panels 180 degress around, you can raise the tilt 15-20 degrees for parties with standing guests, or leave them level. Ingenious design. I read that Martin Logan put significant engineering effort into the panel and bass integration and the new CLS2 bracing that is now on all their speakers. These have tremendous gal appeal.
Available for front door pickup in West Chester, PA 19380. They fit easily in a 4 dr sedan like a Honda Accord or Acura TL. Comes with ALL accessories all in EXCELLENT condition. Martin Logan Grotto subwoofer is excellent condition is available separately at $350. Rating this 7/10 because it has some slight smudges not noticeable from a distance. It is quite in nice shape--and c'mon, it's a sub that sits in a corner. This got hardly used.
Please see pictures at Audioasylum or Audiomart.  Thanks. Grotto is available separately for $350 and I can do a deal if someone buys both--picked up at front door.
https://www.usaudiomart.com/details/649631749-martin-logan-source-speakers-immaculate-condition-grotto-subwoofer-optional/
Included with this sale
1 PAIR Martin Logan Source CLS2 pair of speakers AND ALL ORIGINAL ACCESSORIES, including:
1 Tilt Platform
8 Spikes
2 Energizing adapters
2 Sock covers
2 User Manuals
Frequency Response 42–22,000 Hz ±3dB
Recommended Amplifier Power 20‒400 watts per channel
Horizontal Dispersion 30°
Vertical Dispersion 28" (71cm) line source
Sensitivity 90 dB/2.83 volts/meter
Impedance 5 Ohms, 1.6 @ 20kHz. Compatible with 4, 6, or 8 Ohm rated amplifiers.
Crossover Frequency 470Hz
High Frequency Transducer Generation 2 CLS™ electrostaic transducer
» Panel Dimensions: 28" × 8.6" (71 × 22cm)
» Radiating Area: 241 in2 (1,562 cm2)
Low Frequency Transducer
8" (20.3cm) high excursion, high-rigidity paper cone with extended throw drive assembly, non-resonance asymmetrical chamber format; bass reflex
Components: Custom-wound audio transformer, air core coils
Inputs Custom 5-way binding posts
Weight 47 lbs. (21.4 kg)
Dimensions 51.2" × 9.7" × 14.6"
(130cm × 24.5cm × 37cm)
« Last Edit: 7 Jul 2020, 07:42 pm by nurxhunter »
I.Greyhound Fan
Is that a Grotto i or just the original Grotto?
nurxhunter
Grotto--no 'i'.  Original model.  Thanks.
