Bryston 7B SST3 specs differ from SST2, why?
0 Members and 1 Guest are viewing this topic. Read 1089 times.
Sasha
« on: 27 Jun 2020, 06:37 pm »
Hi James,
I was wondering if you could offer an explanation, 7B SST2 shows slew rate as >160V/µs while SST2 shows >60V/µS, why would that be the case?
Sasha
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston 7B SST3 specs differ from SST2, why?
« Reply #1 on: 27 Jun 2020, 07:02 pm »
Hi James,
Sasha
Hi Sasha
I think that is incorrect - the SST2 was also 160 but I will confirm with engineering.
james
Sasha
« Reply #2 on: 27 Jun 2020, 10:54 pm »
I just realized I typed the question incorrectly, the specs for SST3 show >60V/µS, while for SST2 show >160V/µs. Maybe digit "1" was lost when manual was composed for SST3?
« Reply #3 on: 28 Jun 2020, 12:22 am »
HI
I think you are correct.
james
Mike Pickett
« Reply #4 on: 29 Jun 2020, 01:51 pm »
For all of our common ground amplifiers, including the 4B, 3B, and 2B, the slew rate is 60 V/ms.  For all bridged mode amplifiers, including the 7B, 14B, and 28B, the slew rate is double, at 120 V/ms.  This applies to all SST/SST2/Cubed models.
Unfortunately, some owner's manuals made it to print with errors in the slew rate specifications...
Mike
