Use of PI Audio Mr T diffusor
0 Members and 1 Guest are viewing this topic. Read 2317 times.
Bassaholic
« on: 24 Jun 2020, 08:22 pm »
As far as the Pi Audio foam diffusor panels- what did you guys do to mount them? A mobile frame or wall mount? What did you use to mount them?
Pics would be helpful if you made a frame- thanks in advance.
nature boy
Re: Use of PI Audio Mr T diffusor
« Reply #1 on: 24 Jun 2020, 08:32 pm »
Mounted on rear wall behind speakers and 1st order reflection points on side wall. I used 2" stainless steel T pins (used in sewing).  They easily attach to drywall since the diffuser panels are light.  Some folks use velcro. Pix below.
NB
mikeeastman
« Reply #2 on: 24 Jun 2020, 09:05 pm »
I hung mine from ceiling and made it removable, as it's in front of wood stove and even though haven't had a fire in it in over ten years, you never know. Covered mine with very thin cotton cloth and per my deal with wife, I can put what ever I like on walls but she gets to dye the fabric covers.
Don't know why pics side ways?
Bassaholic
« Reply #3 on: 24 Jun 2020, 09:08 pm »
Cool applications, guys. Thanks
Jon L
« Reply #5 on: 25 Jun 2020, 01:22 am »
used these
https://www.amazon.com/gp/product/B073XR4X72/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
You bought these from Amazon or local store?
There are tons of bad reviews on Amazon that warn the Amazon one is a bad knockoff and to make sure to buy from local store, sight seen.
Jon L
« Reply #6 on: 25 Jun 2020, 02:05 am »
I received a bunch of Pi Audio diffusers I need to hang  :thumb:
RonP
« Reply #7 on: 25 Jun 2020, 01:53 pm »
That's the direct link from my amazon order history. If you order 3M and brand X shows up, Amazon will make it right.
nature boy
« Reply #8 on: 25 Jun 2020, 02:16 pm »
Bought mine directly from Greg Rael (Pi Audio Group). He lists his panels on Audiogon. Great reviews and well packaged. Sound amazing.
NB
Ryan0348
« Reply #9 on: 25 Jun 2020, 05:37 pm »
I bought 10 panels to use with my super minis. I had to coat 4 of them with woodglue that were right behind the suoer minis because there were to absorbent and made the top end roll off. They still diffuse very good just more reflective. The rest are to the sides and celling above the speakers. I bought a new house and im gonna need a few more boe because my space is 28x27ft
