Servo in smaller cabinet
0 Members and 1 Guest are viewing this topic. Read 776 times.
mikeeastman
« on: 22 Jun 2020, 04:39 pm »
I'm changing the sub in my bedroom system to a servo sub and as my sub cabinet is built into my entertainment center I don't want to build a new cabinet. The existing cabinet is only 1.9cu ft and the servo calls for 2 cu ft will the .1 cu ft make much a difference?
S Clark
Re: Servo in smaller cabinet
« Reply #1 on: 22 Jun 2020, 04:47 pm »
I've always heard that +-10% is not an appreciable factor... and even less for servo.  You should be ok.
mikeeastman
« Reply #2 on: 22 Jun 2020, 05:43 pm »
Thats what I thought, but wanted to make sure. Thanks
Jaytor
« Reply #3 on: 22 Jun 2020, 06:20 pm »
You can also play around with different amounts of stuffing material which will change the effective volume of the cabinet. But I wouldn't bother unless you are finding problems with the bass response.
mikeeastman
« Reply #4 on: 22 Jun 2020, 06:41 pm »
As it's my bedroom system that doesn't get played that loud should be fine.
