New Screw for Bryston BDP-1
0 Members and 1 Guest are viewing this topic. Read 1330 times.
RonCH
« on: 22 Jun 2020, 06:09 am »
Hello,
In replacing the battery on the Motherboard of my BDP-1 I have rounded off one of the Torx T8 screws.  Can I buy a new screw?
Ron
  • The Demo is Everything!
    • http://www.bryston.com
Re: New Screw for Bryston BDP-1
« Reply #1 on: 22 Jun 2020, 09:45 am »
Hi Ron
Yes the remote cost $5.00 but the screw is $200.00  :icon_lol:
Just kidding - send me the address and I will send you some screws.
[email protected]
RonCH
« Reply #2 on: 22 Jun 2020, 02:57 pm »
Thanks very much!  You've got to love Bryston's service!
terrycym
« Reply #3 on: 29 Jun 2020, 06:10 pm »
Hi James, can I have some as I had to drill mine out as they were so tight
Terry
WildPhydeaux
« Reply #4 on: 30 Jun 2020, 12:09 am »
No kidding eh? I had to open my BDP-3 up to put a hard disk in and they were wildly tight. One was so tight that the threaded insert in the case itself broke loose, then I had a hell of a time getting that screw out with the loose "nut" spinning inside the case. Needless to say my case now sports an open hole. Sheesh...
Robert
