Precision Loudspeaker Purifiers. $295
0 Members and 1 Guest are viewing this topic. Read 518 times.
Audiophile58
« on: 17 Jun 2020, 02:17 pm »
These are my latest best price performance Clarifiers to date . These are for the Audiophile looking for added refinement.I designed these after my synergistic Xot carbons stopped working  I found out inside was a RC circuit but with very low cost parts. I have built over 350 to date  especially to overseas dealers. All your equipment no matter how expensive Has switching noise,magnetic  RF , EMI and goes downstream out to your loudspeakers, Which Too create  magnetic fields . These High quality  Clarifiers filter noise where it is most present in the high frequencies. I use top name quality Only,worlds best Path Audio resistors,and Audionote Foil -paper oil capacitors.with specific size capacitor,Resistor,and is built to your specific ohm and type of Loudspeaker . where the other brand charge $150 more and a one size fits all which is impossible for Loudspeakers range 8,4,2 ohms.These will remove high frequency noise That masks low level detail above  The 10k hz range . Bananas or spades they work Well on Any Loudspeaker. Please see my feedback,on Audiogon-Audioman58, Thank you.
« Last Edit: 28 Jun 2020, 04:25 pm by Audiophile58 »
Doublej
Re: Precision Loudspeaker Purifiers
« Reply #1 on: 19 Jun 2020, 01:27 pm »
Price?
Audiophile58
Re: Precision Loudspeaker Purifiers. $295
« Reply #2 on: 19 Jun 2020, 01:33 pm »
Hello These are $295  . Look at the Synergistic Xot at $450 for no name parts in a tube
The path audio resistors alone are $30 each x2 . I use only top quality components in my builds sonic purity is essential, thank you, Paul.
