0 Members and 1 Guest are viewing this topic. Read 942 times.
Welcome from Minnesota! Where in WI do you live?You may want to consider the Pass Labs B1 Buffer/preamp kit. You can build it for less than $300. The biggest expense would be aBlue Alps volume pot if you want the remote control version. It has no gain so it is passive. I built one with my son and it sounds great although we used boutique capacitors and resistors. Otherwise I would go used and buy and old adcom preamp or Parasound on Audiogon.com. Schiit audio has a preamp called the Saga that can be used as solid state or tube. But it is $399 and worth the money. https://www.passdiy.com/project/preamplifiers/b1-buffer-preamphttps://www.audiogon.com/listings/lisa3434-parasound-pre-amplifier-zpre2-solid-state
Welcome!Am familiar with most of your brands. Had a Rotel "2.1 A/V" receiver - it was a dog, poor sounding and died right after the 10 year warrantee expired. Have heard several Paradigms of that model line, sound OK but nothing about them stood out - mid-fi sound. Replaced the Rotel with a factory refurbished Harmon Kardon receiver for 20% of the cost - sonically performed much better but kept blowing diodes. A friend had GR Research monitor for a few years, pretty duddy sounding especially in treble response, he now runs Elac speakers. Not a fan of GR Research, designs are decades old, Danny keeps finding different ways to use the same woofer and tweeters, even using the same driver as a woofer and midrange in the same speaker (X-Statik for instance) which makes no sense.Presentation between open baffle and monopole will be different, but in general I'd say less defined. And the X-Statik is an MTM design, which was intended for A/V use and increases efficiency of midrange/woofer drivers but also cuts impedance in half. MTM design can cause phase cancellations if your head isn't exactly between the midrange drivers.
I live about 30 minutes NE of Milwaukee in Hubertus. I was actually looking at the passive Schiit SYS for a measly $49, as this looks like it might actually be all that I need, as my preamp is located directly beside my power amplifier, and all really need is a volume control. It sounds like the solid state version of the Schiit Saga may be available for $299, but I am not really sure why I would need further pre-amplification. Would money be better spent a discrete DAC? The Parasound unit looks nice too, but this too may be overkill for my needs. The DIY kits are interesting, but a bit too industrial looking for our living room. Great suggestions - Thanks!
