FS - Audio-Technica OC9ML/ii BNIB - NO LONGER AVAILABLE.
0 Members and 1 Guest are viewing this topic. Read 487 times.
Sonny
NO LONGE AVAILABLE!
Thanks for looking.  I have a brand new in box, AT-OC9ML/ii.  I bought as a back up but decided that I don't need one as I don't listen to much vinyl.
Here are the specs:
Audio-Technica AT-OC9ML/II Phono Cartridge Specifications
- Type: Moving coil
- Output voltage: 0.4mV
- Frequency range: 15Hz - 50kHz
- Recommended load impedance: 20 ohms or higher
- Channel balance @ 1 kHz: <1dB
- Channel separation @ 1kHz/10kHz: 32/21dB
- Stylus shape: Microline
- Stylus construction: Nude square shank
- Cantilever: Gold-plated solid boron
- Wire used for coils: PCOCC
- Dynamic compliance: 9 x 10-6cm/dyne
- Static compliance: 35 x 10-6cm/dyne
- Recommended tracking force: 1.25 - 1.75 g
- Dimensions: 1.01 x 0.66 x 0.68
- Color: Gold/Black
- Weight: 8.0 g
- Mounting: ½ inch
You can search for pictures, they will probably be better than the one I have that is still in the box.  :)
Thanks for looking
« Last Edit: 27 Jun 2020, 04:42 am by Sonny »
