FS: Nuprime DAC-9. Excellent condition
0 Members and 1 Guest are viewing this topic. Read 635 times.
jakeg104
« on: 5 Jun 2020, 05:44 pm »
SOLD!
Up for sale is a Nuprime DAC-9 in Excellent condition. This is one of the affordable DACs that punches above its price point. Here is a quick summary of the details-
Several notable features:
NuPrime SRC IC chip provides FPGA processing where Input signals are up-sampled to mega hertz before down converted to the targeted sampling rate with ultra-low jitter and distortion.
AKM Newest Generation: High Sound Quality Premium 32-bit Stereo DAC (AK4490 EQ). State-of-the-art DAC with warmer sonic characteristics, supporting USB PCM 384 and DSD256.
A proprietary NuPrime implementation that is also capable of decoding DoP formats via coaxial and optical inputs (to support NuPrime Omnia portable device that are able to output DoP stream in addition to S/PDIF).
NuPrime vibration-free isolation feet (patent pending*)
Extension port for Bluetooth dongle and WiFi audio streaming (optional)
Full microprocessor control with memory retention
Five digital inputs and one stereo input for complete system flexibility
Supports DSD native playback by ASIO2.1 and DoP method. DSD is decoded natively with the same sample rate as the input source.
Ultra-low-noise JFETs in the input stage for the lowest possible noise floor
Volume adjustment in 99 precise 0.5dB increments
Advanced, FPGA implemented thin-film switched-resistor ladder network for controlling volume, with a single resistor in the signal path at any volume setting
Individually adjustable volume on each input for precise level matching of sources. If DAC-9 is connected to another preamp or home theater AVP, set the volume @ 94, which is 0dB.
Exclusive driver software for Windows
Standard driver software for Mac
Asynchronous transfer mode
Very low power consumption on Standby Mode
Inputs:
• 1 x USB PCM / DSD Digital (PCM up to 384kHz & DSD up to DSD256 )
• 1 x Coaxial Digital S/PDIF (PCM up to 192KHz supporting DoP format DSD64)
• 1 x Optical Digital S/PDIF (PCM up to 192KHz supporting DoP format DSD64)
• 1 x Bluetooth or WiFi receiver module (optional).
• 1 x AES balance XLR
• 1 x Analog Stereo RCA (does not go through A2D conversion, analog input is selected by the preamp directly to analog outputs)
Outputs:
• 1 x pair of stereo RCA out (max output 4V)
• 1 x pair of stereo XLR balanced out (max output 8V)
• 1 x Optical S/DPIF out
• USB Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, 192KHz, 352.8KHz, 384KHz and DSD 2.8MHz(64), 5.6MHz(128), 11.2MHz(256)
• S/PDIF Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96, 176.4KHz, 192KHz, 352.8KHZ, 384KHz (Coaxial)
• Bit Resolution: 16-32-bits
• THD+N: 0.0015%
• Dynamic range: >-113dB
• Frequency Response: 10Hz to 80kHz
• Dimensions: 235 mm W x 281 mm D x 55 mm H (including feet)
• Weight: 2.3Kg
• Worldwide AC voltage: (90VAC~130VAC // 210VAC~ 250VAC) With Voltage Select Switch
• AC Fuse: Slow-blow, 1A, 250VA
There have been glowing reviews written about this DAC, this is an opportunity for you try out one of these at a lot less than retail price.
https://www.theabsolutesound.com/articles/nuprime-dac-9-dac-sta-9-stereo-amp-and-hpa-9-phono-preamp-and-headphone-amp/
https://headfonics.com/the-dac-9-by-nuprime/
Unit will come with the supplied remote control, manual, original box. Will be double boxed and shipped with a tracking number.
« Last Edit: 6 Jun 2020, 11:02 pm by jakeg104 »
