Tyler Acoustics PD10
0 Members and 1 Guest are viewing this topic. Read 992 times.
Kw6
« on: 31 May 2020, 03:00 pm »
Hi Danny,
Did I read you designed the crossover for Tyler Acoustics PD10? If so do you have any measurements that you can post? Is it a smooth sounding and detailed speaker? Thanks!
Danny Richie
    • http://www.gr-research.com
Re: Tyler Acoustics PD10
« Reply #1 on: 31 May 2020, 10:57 pm »
Hi Danny,
No, I didn't design any of those models or their crossovers.
Kw6
« Reply #2 on: 1 Jun 2020, 02:17 am »
Ok thanks!
