Bryston serial number ?
0 Members and 1 Guest are viewing this topic. Read 2874 times.
bunkertoy
« on: 31 May 2020, 02:15 pm »
Been searching for a serial # look up website. Many people have different theories on how to look up a Bryston serial #
Mine is 809761 , I believe its an 8, serial numbers look a bit smudged.
Phil A
Re: Bryston serial number ?
« Reply #1 on: 31 May 2020, 02:17 pm »
Date code is a way to look up how old your equipment is and whether it is in the warranty period
https://www.audiocircle.com/index.php?topic=68980.msg639631#msg639631
bunkertoy
« Reply #2 on: 31 May 2020, 07:54 pm »
No date code, just serial # on the amp
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 31 May 2020, 07:58 pm »
Hi
Beginning in an 8 would mean its an 8B Amplifier.
james
bunkertoy
« Reply #4 on: 31 May 2020, 08:05 pm »
That's odd James, it clearly says its a 3B, here is a picture of the serial #
« Reply #5 on: 31 May 2020, 08:32 pm »
OK that's a 3 not an 8 - terrible silk-screen!
james
bunkertoy
« Reply #6 on: 31 May 2020, 08:47 pm »
Wow, good for you being able to decipher that. so does that mean 9 th month 76 yr ?
srb
« Reply #7 on: 31 May 2020, 09:29 pm »
If that's correct then the 6-digit serial number could only differentiate between 10 unique units per month?  :scratch:
bunkertoy
« Reply #8 on: 31 May 2020, 09:37 pm »
I'm only guessing, looking at other threads with the same request. The only consistent part of the serial number is the product which is referred by the 1st number after that its just random I believe.
« Reply #9 on: 31 May 2020, 09:47 pm »
Email MIke and he can look up the production card and tell you the details.
[email protected]
james
bunkertoy
« Reply #10 on: 31 May 2020, 09:51 pm »
Thanks, I'm actually going to send the amp in for a new power cord. I'll ask him then. Thanks again for your time James.
WildPhydeaux
« Reply #11 on: 31 May 2020, 10:40 pm »
Wow, other than the information tag, how can you tell this is made in Canada? Red Robbie anyone? Nice!
Robert
