Issue with an SP4
0 Members and 1 Guest are viewing this topic. Read 591 times.
CEEDUBYA
Issue with an SP4
« on: 30 May 2020, 01:35 pm »
Hi,
I have an SP4 in my cinema system working with an Oppo 205 player. When viewing "SOME" Blu Rays and it seems to be primarily DTS content, I experience random audio dropouts. They're not extreme in length and there is no logic as to when they will occur. It appears to be, the issue can apparently be solved by setting the Oppo to control output using PCM rather than letting the SP4 handle Bitstream. This is technical and I must confess way way above my head but I believe this is what is happening. It is being looked at extensively by all the clever people who have all been GREAT but I'm keen to hear of anybody else having any similar problems. Apparently, the SP4 receives a rogue "MUTE" command but its source cannot be traced. Another player (Sony) has also been tested with the same results. The HDMI board was also changed. Does anybody have any thoughts on this please? Thanks, it would be great to try and solve this little annoyance.
CW
