Industry Circles
Bryston Limited
BDP-3 not loading files from attached drives
0 Members and 1 Guest are viewing this topic. Read 596 times.
docder
27 May 2020, 08:19 pm »
I have restarted a BDP-3 after changing network from wireless to ethernet to find that the audio files on the attached hard drives are not loading to MDP list. The hard drives are all listed and marked in red at the bottom of the Home tab but none are appearing as being loaded to the play area. And there no U for update showing on the display screen. What has gone wrong? Never had this problem before now after a restart, or reset of Network or Global settings.
D
docder
Re: BDP-3 not loading files from attached drives
27 May 2020, 08:48 pm »
Ah, disconnecting the drives from the USB inputs and reconnecting seems to have set uploading into go mode. U has appeared in display, database building underway, smaller drives have appeared in Home list, let's see how it goes ...
unincognito
Industry Participant
ยป
Reply #2 on:
28 May 2020, 03:43 pm »
Hi Docder,
You can tell the BDP to update its database by using the update button found next to clear and consume, I've included a link to the manic moose manual below.
http://support.bryston.com/downloads/BDP/Manic%20Moose%20Manual.pdf
Chris
Industry Circles
Bryston Limited
