Three Duals!
0 Members and 1 Guest are viewing this topic. Read 3027 times.
Early B.
Three Duals!
« on: 25 May 2020, 01:41 pm »
Wife changed the furniture around. She put the sofa near the back wall, so I had to move my third sub. Decided to try it front & center. Wow! Aside from bigger, badass bass, the soundstage improved - more prominent peripheral details. (Not sure of the science behind bass affecting the entire sound spectrum -- maybe someone can explain it here.)
Dialed it in. Placement didn't create any imaging issues. Room is 13 ft. wide; speakers are 32" from the side walls. Since my system is in the family room, I may have to move the middle sub in place every time I listen critically. It's a minor inconvenience that will only take a few seconds. No spikes or footers -- the sub slides easily on the wood floor without scratching it.
DeeJayBump
Re: Three Duals!
« Reply #1 on: 25 May 2020, 02:21 pm »
Nice setup and thanks for sharing.
AverageNiceGuy
Re: Three Duals!
« Reply #2 on: 25 May 2020, 04:39 pm »
Nice!
Three subs, and one wife... that seems safe enough!  8)
Danny Richie
Re: Three Duals!
« Reply #3 on: 26 May 2020, 01:16 pm »
Try laying it on its side.
And then build a stand for that center channel to get it up closer to your screen.
RonP
Re: Three Duals!
« Reply #4 on: 26 May 2020, 03:30 pm »
Could you do a swarm-like setup and place the center dual at the back of the room?
just curious
AKLegal
Re: Three Duals!
« Reply #5 on: 26 May 2020, 04:32 pm »
just curious
I think that is where it was before the couch was moved.
Rocket_Ronny
    • ScriptureSongs.com
Re: Three Duals!
« Reply #6 on: 26 May 2020, 04:43 pm »
Very nice.
What people need to realize is by using the dual subs with monitors of your choice on top, you can get world class sound on a beer budget and those monitors would deliver the goods.
If I were starting all over again, I would get Danny’s dual subs, or the Rythmik FN-8s, and some open baffle, high efficiency, upper section from Danny, or may experiment myself. The speakers are just that good.
Rocket Ronny
Glady86
Re: Three Duals!
« Reply #7 on: 26 May 2020, 05:06 pm »
Thats wimpy man, I plan on at least four triples.   :icon_lol:
Early B.
Re: Three Duals!
« Reply #8 on: 26 May 2020, 05:07 pm »
OK, I'll try laying on it's side. I'm shocked my wife hasn't said anything about it, so I may be able to keep as is.
Regarding the center channel -- I don't care about HT anymore, so tweaking the sound quality is a very low priority. Movies suck nowadays. No story, just comic-based super heroes. I'm bored just thinking about it. We watch a movie like once or twice a year.
Early B.
Re: Three Duals!
« Reply #9 on: 26 May 2020, 05:15 pm »
just curious
The third sub was originally on the back wall, but when we placed the sofa in front of the sub, it sounded like it was in a tunnel. I had to find another place for it. I'm guessing it will sound better front & center as opposed to being on one of the side walls. It's playing up high enough where you can locate the sound.
Danny should design a wall-hanging servo sub. 8)
Re: Three Duals!
« Reply #10 on: 26 May 2020, 05:18 pm »
Sealed subs do better at the back of the room.  OB subs do better at the front, IME.
Early B.
Re: Three Duals!
« Reply #11 on: 26 May 2020, 05:58 pm »
Problem is -- sealed servo subs don't sound as good as OB servo subs. I suppose the decision to add a seal sub(s) in the back depends on musical tastes, as well. Trade-offs.
RonP
Re: Three Duals!
« Reply #12 on: 16 Jun 2020, 05:33 pm »
Hey Early
I wanted to thank you for this post. I hadn't thought about buying a single dual-12" sub and putting in the center.  It's a stop over on the way to stereo triple-12"s and associated flatpaks. I need to go pickup my cabinet from a local carpenter. They hit me up today and it's done.  :thumb:
Early B.
Re: Three Duals!
« Reply #13 on: 16 Jun 2020, 08:05 pm »
Hey Early
Good move. I started with a single dual servo sub in the center until I could save up for a second sub. That's one of the major benefits of DIY that's often overlooked -- you can take incremental steps to achieve your goal based on your budget and other factors.
Re: Three Duals!
« Reply #14 on: 18 Jun 2020, 09:36 pm »
IIRC,  Danny  typically  ran  2 sealed subs in the rear of his room at  RMAF withthe OB  triples up front.  The rear subs are  run out of phase from the fronts  and  at  a much  lower  volume
jay
Danny Richie
Re: Three Duals!
« Reply #15 on: 24 Jun 2020, 10:35 pm »
jay
And that worked really well.
Early B.
Re: Three Duals!
« Reply #16 on: 25 Jun 2020, 01:04 am »
I imagine it would! What was the room size?
