Candela pre out
0 Members and 1 Guest are viewing this topic. Read 1307 times.
erniek
Candela pre out
« on: 21 May 2020, 06:24 pm »
What is the 2nd pair of preouts on the Candela used for. They are not marked so I didn't think it was for the HT bypass which is marked.
Audio72
Re: Candela pre out
« Reply #1 on: 21 May 2020, 08:35 pm »
Maybe for some powered subwoofers?
uncola
Re: Candela pre out
« Reply #2 on: 23 May 2020, 12:37 pm »
Maybe tape loop out?  Or like he said for subs or to biamp?
Phil A
Re: Candela pre out
« Reply #3 on: 23 May 2020, 04:21 pm »
The Odyssey unified manual (see page 26 of 28) - http://www.odysseyaudio.com/odyssey-unified-usersmanual.html  indicates the 2nd pair of pre-outs is optional.  It as noted above can be used for a subwoofer or to biamp or if one has connections to another room to control an amplifier in there (and one can use something like https://www.ebay.com/i/183970366294?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=183970366294&targetid=884733315753&device=c&mktype=pla&googleloc=9011833&poi=&campaignid=9423618915&mkgroupid=95235863706&rlsatarget=pla-884733315753&abcId=1141016&merchantid=114626621&gclid=EAIaIQobChMI1cDI97HK6QIVlovICh2taQATEAQYASABEgLNHfD_BwE    to control the Candela from the other room).
