Aksa TLP's Transformer Rating
0 Members and 1 Guest are viewing this topic. Read 2364 times.
Junior
« on: 23 Feb 2005, 12:38 am »
Hi,
I do understand that the transformer for the TLP is custom made with 150V and 6 Volts Secondary out. But I did not manage to find its VA rating. Would anyone here help me determine the VA rating for the TLP transformer.
AKSA
« Reply #1 on: 23 Feb 2005, 12:45 am »
Hi Junior,
It's rated at 25VA, and uses grain oriented silicon steel to better contain the magnetic circuit and thus reduce hum and operating temperature.
Hugh
Junior
« Reply #2 on: 23 Feb 2005, 09:56 am »
Thank you Sir for the quick reply.
Last question.
Is there any sonic improvement if higher rating VA is used?
Good day
AKSA
« Reply #3 on: 23 Feb 2005, 09:57 am »
Junior,
In a word..........    No.
Hugh
Junior
Transformer's Primary and Secondary Winding.
« Reply #4 on: 28 Feb 2005, 05:35 am »
Please do help me in understanding the transformer winding in the Aksa TLP.
Correct me if I am wrong.
Primary Winding:     115-0-115-0
Secondary Winding: 150-0 (or 75-0-75-0)
                              6.3-0
                              15-0-15 (for future development)
AKSA
« Reply #5 on: 28 Feb 2005, 05:58 am »
Hi Junior,
Primary is correct.
Secondary HT is simply 0-150V (no center tap)
Filament is 6.0V (to lengthen life of the filament and accommodate higher mains voltages, which are extremely common these days)
CT supply is 17-0-17Vac.
Hope this helps!
Hugh
Junior
« Reply #6 on: 28 Feb 2005, 09:41 am »
I do understand HT stands for High Tension.
But what do CT means?
Pardon my ignorance :oops:
AKSA
« Reply #7 on: 28 Feb 2005, 11:23 am »
CT means Center Tap!
Hugh
