Bel Canto e.One S300iu integrated with USB input - $825
0 Members and 1 Guest are viewing this topic. Read 731 times.
smccull
I have really enjoyed this well reviewed integrated but I am going back to high efficiency, single driver speakers and just don't need the power.
It's in very good condition. There are two hardly visible smudges in the black powder coat finish on top, and a very slight ding on the top corner edge of the aluminum face plate. These slight imperfections are very difficult to see unless you're right up on the amp, and were pretty much impossible to get to show up in the pictures, but I do want to be accurate in the condition.  I have the remote and original box. I will double box it and insure it for the full value if I ship it.
$825.00
Description: Integrated amplifier with USB DAC.
Preamplifier section: Frequency range: DC–200kHz. Signal/noise (A-weighted, ref. 2V RMS): >95dB, Input overload: 10V. Input impedance: 10k ohms. Output impedance: 500 ohms. Maximum gain: 20dB. Maximum output level: 9.5V.
Amplifier section: Maximum output power: 150Wpc into 8 ohms (21.75dBW), 300Wpc into 4 ohms (21.75dBW). Minimum rated load impedance: 4 ohms. Frequency response: 20Hz–20kHz, ±0.5dB. Voltage gain: 27dB. Damping factor: >1000. Output impedance: <8 milliohms. THD+noise: 0.01% (1kHz at 1W into 4 ohms). Dynamic range: 111dB (no test conditions quoted).
« Last Edit: 27 May 2020, 01:35 am by smccull »
