Does input impedance double or halve with two amps?
0 Members and 1 Guest are viewing this topic. Read 1691 times.
warnerwh
« on: 22 Feb 2005, 10:01 pm »
I need to know if I hook two amps to my pre will that increase the input impedance the preamp sees or will it be the total of the two amps divided by two. Thanks
Occam
« Reply #1 on: 22 Feb 2005, 10:06 pm »
Assuming they are the same amps, the impedance load seen by the source would be 1/2 the impedance of a single amp.
The generalized formual for impeances/resistances in parallel is
Rt = (R1 x R2) / (R1 + R2)
JoshK
« Reply #2 on: 22 Feb 2005, 10:06 pm »
halve  (because you are running the amps in parrallel).
WEEZ
« Reply #3 on: 22 Feb 2005, 10:07 pm »
The total divided by two. (assuming both amps have the same input z and your pre-amp outputs are not independent outputs- but are paralleled)
WEEZ
warnerwh
« Reply #4 on: 23 Feb 2005, 12:33 am »
Appreciate the help. Thanks guys
jeffreybehr
« Reply #5 on: 23 Feb 2005, 04:32 pm »
Speaking of resistors in parallel, here http://www.1728.com/resistrs.htm is a site that will calculate the net results of having as many as 10 resistors in parallel.  I use it for calculating net gage of multiple-conductor speakercable, among other things.
eico1
« Reply #6 on: 23 Feb 2005, 09:16 pm »
Your capacitive load will double!
steve
