Using old preamp phono stage with new line stage preamp?
0 Members and 1 Guest are viewing this topic. Read 896 times.
urbanshaman
I should just try this myself, but I'm wondering if anyone is using, or has tried to use, an older preamp with a good phono stage connected to a newer line stage preamp. I'm thinking one could simply use the tape out of the old preamp to any input of the line stage. This might be a way to avoid buying  an outboard phono stage that could be costly.
sunnydaze
Re: Using old preamp phono stage with new line stage preamp?
« Reply #1 on: 18 May 2020, 04:44 pm »
That's exactly the correct way to do it.
I've done it many times to access the phono section inside older receivers, integrateds, etc.
Elizabeth
« Reply #2 on: 18 May 2020, 04:59 pm »
I own a half dozen preamps. I have at least three other preamps connected to my main preamp. And yes two of them are for the phono stage in the secondary preamp.
Works great.
